Hi all,
Actually I am doing precommissioning for MOV valve using ROTORK Actuator IQ range. Actually, the Actuator is installed on the MOV and all cables are connected to DCS
I tried on site to close and open the vale with selector on LOCAL. it runs good.
BUT
When I select REMOTE on site, on DCS the signal REMOTE is displayed only one second; then I cannot open and close from DCS.
I need your help
These all data about the vale and ROTORK actuator<pre>
REPERE 009-MOV-402
FONCTION VANNE MOV SORTIE RAMPE DE COMPTAGE 4
TYPOLOGIE BOISSEAU SPHERIQUE
BRIDE TAILLE 24
TROU TAILLE 24
FAIL ACTION BLOQUEE A LA MEME POSITION (FAIL LAST)
FABRICANT O.M.S. SALERI
MODELE S7100.T.AW.SF.600.EP
TEMPS OUVERTURE/ FERMATURE 3 sec/inch - 3 sec/inch
ACTIONNEUR
TYPE ELECTRIQUE
ALIMENTATION (Alimentation Principale) 400 Vca 50Hz 3Ph
ALIMENTATION (Circuit Auxiliaire) 24 Vdc
FABRICANT ROTORK
MODELE IQ20 B4 96RPM 400/3/50
OVERRIDE ROUE MANUEL
Drawing : RWS100 (100B0000-6)
Wire ACtuator to DCS action
6-7 limit switch Close
8-9 limit switch open
10-11 LOCAL/REMOTE
42-43 FAULT
33-34 CLOSE COMMAND
35 OPEN COMMAND
5 STOP COMMAND
********************************************</pre>
I used a Bluetooth to configure but it is not easy for me
Thanks for your help
BUT
I need your help
REPERE 009-MOV-402
BRIDE TAILLE 24
TROU TAILLE 24
ACTIONNEUR
TYPE ELECTRIQUE
FABRICANT ROTORK
10-11 LOCAL/REMOTE
42-43 FAULT
33-34 CLOSE COMMAND
35 OPEN COMMAND
5 STOP COMMAND
