On site we have a triple pressure HRSG, HP/IP/LP with re-heater, 125/28/3 bar, max flow 300 tn/hr in HP, flue gas vertical flow, with exhaust gas from a 9FA GT, multi shaft arrangement. After almost 54000 fired hours we have measured reduced thickness in HP ECO tube bends, not in all of 4 modules but in the 3rd and 4th one, mainly in the middle, nominal thickness was 4.2 and measured was found 3.2-3.3mm. We proceeded with tube bends replacement but as you understand this is a high cost activity taking at least 3 weeks. My question is if with your experience, you found similar tube thickness reduction issues, what could be the causes and the corrective actions? The tube material is SA210 AL (carbon steel), operating pressure 155-175 bar, temperature inlet at 145oC and outlet at 310-320 oC.
Please advise.
Please advise.
