I need VFD firmware dump
Dears,
Hi
kindly I need Mitsubishi FR-A840-00126-1-N6 VFD firmware dump for primary and secondary flash memories, thanks in advanced.
Have you tried contacting Mitsubishi Electric's technical support or an authorized service center? They may be able to provide the correct firmware files or advise on the recovery procedure for that specific FR-A840 model.
I'd be a bit careful about using a firmware dump from another drive, even if the model number is the same, since hardware revisions and firmware versions can differ. It would be worth checking the exact hardware revision and firmware version before attempting to write anything to either flash memory.
Hopefully someone with experience repairing FR-A800 drives can point you toward a reliable source.
