iFix "databasemanager" error: I/O Address entered was rejected by the Server.
Good afternoon everyone,
i was tryng to configure some tags on databasemanager polling datas from IGS server. I'm also tryng to open a databasemanager istance on iFix Client node, when the databasemanager .pdb file is located on the iFix SCADA node. i can't open the databasemanager on scada node cause i can't shut down iFix and re-open-it on demo mode. I've configured OPC power tool properly and the value is read without errors from the IGS server but when i try to configure the tags on databasemanager editor, it rejects the address returning the error description you can see in the title of this thread. i use the same syntax of other already configured OPC tags inside the database but the error continues to appears.
Anyone have met the same issues?
Thank u for the attention,
have a good day.
