Given a 3phase inverter let's say 400vac rms line to line (means 230VAC rms each line referred to neutral of generator).
After the 6 diodes converter stage there is a about 550VDC (approx -275VDC to +275VDC) after the condenser which straighten the humps. This is because the non-rms phases range from -325 to +325V.
Now, what does the process to reconstruct any of the three output phases produces? We have an about, negative to positive, 550VDC. It seems to me that you could recreate at any different frequency :
1) 3 phases with a waveform peak to peak of 550V, -275VDC to +275VDC, but this is about 195VAC rms
2) 3 phases with a waveform peak to peak of 1100V, -550DC to +550VDC, but this is about 400VAC rms
Than of course varying the pulse duration with the igbt you can obtain any voltage from 0 to the maximum. But what is it the maximum, that of case 1), case 2) or, in case I was totally wrong, other?
