P
I am trying to hook-up a bubbler type level measuring system for sump tank with connection to a dP transmitter to DCS. The sump tank is used to collect hydraulic oil, chemicals and liquid disposal from an offshore oil platform.
I am using a 3/8" OD tubing for the instrument air supply and seems that it is not working due to blockage on the tubing. Please recommend what type of tubing is usually required for such liquid measurement. I am proposing to use a 1/2" or 5/8" OD tubing to avoid the blockage. Any suggestion?
