We are searching a small PLC to integrate in a 3U high (132 mm)/19 inches wide (482 mm) rack space. This space must include the space for thermal dissipation and the cabling.
We reviewed many options of many suppliers (Rockwell, Schneider, Siemens, RTP, Hima, Omron, Mitsubishi, Pilz, Wago, Phoenix contact, Gefran, Gilogik, IDEC, ABB, Honeywell, Saia-Burgess Controls, GE Fanuc, Rexroth Bosch Group, Hitachi, IMO, Omniflex, Festo, Jokab, EADS/Racal, VME solutions, Macq Electronique, B&R Automation, National Instruments) and we didn't find anything.
Thanks for you help and propositions of solutions.
The needs in inputs/outputs are the following: 3 RS485 independent channels, 2 Ethernet channels (or 1 with a switch), 7 binary inputs (24VDC), 6 binary outputs (free contacts, 1 NO + 1 NC each), 3 analog outputs (4-20mA, 12 bits minimum).
It's for an industrial use and we would like to have access to qualification information: norms, levels and criteria. Main expected norms are RCCE-2005, CEI 60439, CEI 60068, CEI 61000 and NF EN 55022.
And then, we would like the solution has a correct life time cycle: about 8 to 10 years of stability for hardware and software embedded, about 15 to 20 years of stability for the function.
Thank you.
Thank you.
