I am building a two-level inverter in Simulink and the control technique is used is SVPWM.I have developed the two-level inverter but got struck while building SVPWM...please help me to build the SVPWM
In order to set up a SVPWM system, the first you must know the seven vector V0-V7, in matlab simulink you may take advantage the asynchronization machine as the model to calculate the sequence of vector.
i am dealing with space vector pwm to obtain the six pulses of inverter. At this point the paper named as "space vector modulation- a novel implementation using integer microcontrollers" is very helpful to me. But i couldn't form the pulses from the knowledge of sector number and switching times , do i need a kind of monostable multivibrator? do you know?
