Low-air alarms on packaging equipment: NPN input wiring, hysteresis and filter delay
Selection note for pressure monitoring on an existing packaging station. If the local display looks normal but the PLC reports low air, separate sensing location, electrical behavior and event timing before extending the alarm timer.
1. Sensing location: a pressure point upstream of a restriction can miss what happens at the working branch. Check dynamic pressure at the relevant location and account for a long sensing tube. The sensor port is not the main actuator flow path.
2. Electrical interface: an NPN open-collector pressure-switch output needs a compatible PLC input circuit. The PLC's NPN transistor OUTPUT specification does not establish INPUT compatibility. Verify input common wiring, supply reference and input voltage/current from the exact manuals. Test both switch states.
3. Thresholds: derive the trip pressure from the validated process requirement, then choose a suitable higher recovery threshold. Check units and hysteresis before changing program logic.
4. Timing: sensor anti-chatter, PLC input filtering, scan time and the application timer form one total delay. Excessive filtering can conceal a real short pressure dip. Compare the input transition with the commanded machine cycle.
For component selection, SMC ISE30A-C4L-A-PLA1 supplies two discrete NPN switch outputs and Delta DVP14SS211T supplies PLC sequence logic. This is an interface-review example, not a tested complete installation. Discrete outputs can support an event counter; they cannot deliver a continuous pressure trace. Confirm the exact replacement variant and availability.
Commission startup, power loss and pressure recovery. Two outputs from one sensor are not independent safety channels; process monitoring does not replace validated machine safety functions.
Discussion question: when a pressure dip is shorter than the program alarm delay, what measurements do you capture to distinguish a genuine pneumatic transient from wiring noise or a filtering mismatch?
Disclosure: our commercial product pages, included only as references for the configurations:
SMC: https://www.smc.lat/products/smc-tw...ion-digital-pressure-sensor-ise30a-c4l-a-pla1
Delta: https://delta-ww.com/products/delta...ller-plc-main-unit-dvp-ss2-series-dvp14ss211t
