I'll be grateful if you can found the procedure to activate those spare channels !...@hamid1995,
If someone added a T/C to the panel you're working on then it should be possible to add another if there are unused locations.
I haven't spoken to any former colleagues yet, but looking at the Display Menu and seeing 'Administrative Display' that may be where the input is enable/disabled. But something seems to remind me that there is a special display that is accessed with a code/password to access that display and I just can't remember for certain. SORRY!
I'll ask a former colleague or two; I can't guarantee they will get back to me or how quickly if they do.
In our case, only one spare channel is activated in DS3800NTCD board, all others are inhibited (showing -18°C during test !)Which MARK IV system are you using? The DS3800NTCD board is specifically designed for thermocouple inputs. It has 8 integrated circuits, connectors for communication with other boards, and built-in test points for monitoring signals.
Would you care to share the relevant elementary diagrams?many thanks WTF?
The MARK IV system in question was installed in 1990 (designed in September 1989);
A thermocouple input for “lube oil manifold temperature” LTH , had already been added by a TA in 1993.
I'm currently looking to add thermocouple inputs to the <C> controller to display load gearbox shaft temperatures ;
The procedure for finding spare part positions is explained in the GEK-83886 service manual; as you said, it can be carried out in various ways, such as the Composite Reals page 0F or the Logic Forcing page 16 (see photo) for example.
It seems that the spare data point addresses IDATA are in the same order as the hardware spare positions.
Connecting a thermocouple for simulation in a spare position following LTH shows no change and displays -18 C° all the time, even though we can rename the new thermocouple and choose its scale identical to LTH (scale 163 for type K T/C); it seems that these unused spare analog inputs have been disabled by design ;
| S | Mark vie | Power Generation | 0 | |
| R | GE Mark VIe - Trying to change a TMR setup from a 0-5VDC to a 4-20mA transmitter.. | Power Generation | 10 | |
| S | Mark-5 TBPX card BNC connectors Details | Power Generation | 0 | |
Mark VI RPSM Red light indicator | Distributed Control Systems - DCS | 0 | |
| C | Mark 5 power up sequence | Open Control | 5 |
