We are using two Markvie controls for the Frame 5 turbine. Recently, one of the PDIO modules failed <R>. We tried to replace it with a spare module from our stock. But ToolBox is not recognising the module. We removed and checked the module. This module comes with a sticker from GE, writing to use with IS200TDBTH2A (24V)for TMR control. Our system uses IS200TDBTH6A (125V). We noticed that the module is dead (Attention LED is solid green).
We changed R, S, T modules with new type and changed the foam from H6A to H2A and tried to download. But software is not going through. Changed back foam to H6A (original). Downloaded the software. S and T are ok. So R replaced with the old removed module. That is also ok.
My concern is why the module is fixed with a sticker to use with IS200TDBTH2A, whereas the module is compatible for all types of boards. Will this new module cause trouble in the coming days?
