We are developing an android app for device communication using MODBus Protocal.
Please refer link for solution architecture diagram
We have used the following downloaded libraries Tools.
jamod-1.2-SNAPSHOT.jar has been downloaded from
http://sourceforge.net/projects/jamod/files/latest/download?source=files
mod_RSsim.exe has been downloaded from
http://sourceforge.net/projects/modrssim/
PROBLEM
we can connect android APP with modbus simulator(mod_RSsim.exe) using socket connection. but we couldn't write and read values from registers using functions from "jamod-1.2-SNAPSHOT.jar".
we got output like this 00 00 00 00 00 06 00 03 00 00 00 00 when we use
WriteMultipleRegistersRequest wrq = new WriteMultipleRegistersRequest();
wrq.getHexMessage();
what is the correct function to read and write for registers in modbus simulator using "jamod-1.2-SNAPSHOT.jar".
Our Program<pre>
package com.example.smodbus;
import java.io.BufferedWriter;
import java.io.DataOutput;
import java.io.IOException;
import java.i
utputStreamWriter;
import java.net.Socket;
import java.net.UnknownHostException;
import net.sourceforge.jmodbus.Modbus;
import net.wimpi.modbus.io.ModbusTCPTransaction;
import net.wimpi.modbus.msg.ReadInputRegistersResponse;
import net.wimpi.modbus.msg.ReadMultipleRegistersRequest;
import net.wimpi.modbus.msg.WriteMultipleRegistersRequest;
import net.wimpi.modbus.msg.WriteSingleRegisterRequest;
import net.wimpi.modbus.procimg.Register;
import net.wimpi.modbus.procimg.SimpleRegister;
import android.app.Activity;
import android.os.AsyncTask;
import android.os.Bundle;
import android.util.Log;
import android.view.Menu;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
public class MainActivity extends Activity implements Runnable
private Button buttonSum;
ModbusTCPTransaction trans=null;
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
addListenerOnButton();
public void addListenerOnButton(){
buttonSum=(Button)findViewById(R.id.button1);
buttonSum.setOnClickListener(new OnClickListener(){
@Override
public void onClick(View view) {
new conect().execute();
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.activity_main, menu);
return true;
@Override
public void run() {
// TODO Auto-generated method stub
private class conect extends AsyncTask<String, Void, String> {
@Override
protected String doInBackground(String... urls) {
try {
int port=502;
Socket s = new Socket("192.168.56.2", port);
BufferedWriter out = new BufferedWriter(new OutputStreamWriter(s.getOutputStream()));
String outMsg = "TCP connecting to " + port + System.getProperty("line.separator");
Log.i("TcpClient", "sent: " + outMsg);
SimpleRegister[] registers = new SimpleRegister[1];
registers[0] = new SimpleRegister(15);
WriteMultipleRegistersRequest req = new WriteMultipleRegistersRequest(400001, registers);
Register ras = new Register() {
@Override
public int toUnsignedShort() {
return 0;
@Override
public short toShort() {
return 0;
@Override
public byte[] toBytes() {
return null;
@Override
public int getValue() {
return 0;
@Override
public void setValue(byte[] arg0) {
@Override
public void setValue(short arg0) {
@Override
public void setValue(int arg0) {
ras.setValue(40001);
ras.getValue();
WriteSingleRegisterRequest wrq = new WriteSingleRegisterRequest(Integer.decode("5").intValue(), ras);
ReadMultipleRegistersRequest rea=new ReadMultipleRegistersRequest();
rea.getHexMessage();
DataOutput dout = new DataOutput() {
@Override
public void writeUTF(String str) throws IOException {
@Override
public void writeShort(int val) throws IOException {
@Override
public void writeLong(long val) throws IOException {
@Override
public void writeInt(int val) throws IOException {
@Override
public void writeFloat(float val) throws IOException {
@Override
public void writeDouble(double val) throws IOException {
@Override
public void writeChars(String str) throws IOException {
@Override
public void writeChar(int val) throws IOException {
@Override
public void writeBytes(String str) throws IOException {
@Override
public void writeByte(int val) throws IOException {
@Override
public void writeBoolean(boolean val) throws IOException {
@Override
public void write(byte[] buffer, int offset, int count) throws IOException {
@Override
public void write(int oneByte) throws IOException {
@Override
public void write(byte[] buffer) throws IOException {
rea.writeData(dout);
System.out.println();
//register values
System.out.println(rea.getHexMessage());
out.write(outMsg);
out.flush();
s.close();
} catch (UnknownHostException e) {
e.printStackTrace();
} catch (IOException e) {
return null;
@Override
protected void onPostExecute(String result) {
}</pre>
Looking forward to hear from someone.
Thanks for your help.
Please reply
[email protected]
PROBLEM
Our Program<pre>
import java.i
@Override
return true;
@Override
public void run() {
@Override
try {
int port=502;
@Override
return 0;
@Override
return 0;
@Override
return null;
@Override
return 0;
@Override
@Override
@Override
ras.getValue();
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
@Override
//register values
out.write(outMsg);
out.flush();
s.close();
return null;
@Override
}</pre>
Please reply
[email protected]
