I am using a Siemens PLC which transfers the datas through Modbus TCP/IP. These data to be exchanged with another third party PLC which can access only Ethernet TCP/IP.
Can anyone to tell me how to convert the data from Modbus TCP to Ethernet/TCP. Is there any module can be used in between to do the conversion or any coding can be done at the Siemens PLC side
Please answer my question.
Thank you.
Thank you.
