In our plant, when the production stop for one day, there's less charge on the electrical system. That cause the voltage to go up to about 520Vac (normally 480Vac) at the end of the plant (the cable run is maximum).
The problem is we got some drives that doesn't support that overvoltage and blow out.
Is there a way to keep the voltage to 480Vac even if we stop the production??
