hi. i am working with a packaging company at daman in india. we have one multilayer blown pe-film extruder. my concern is about the parkers ssd drives connected to 3 extruder motors (55kw,55kw and 75 kw) and fixed in the electrical panel of the same m/c.
after commissioning, the m/c ran very wellfor 3-4 months without any problem. but from march onward we have been facing igbt blown off problem for all 3 drives. we have rectified each drive for 3 times from parker chennai. but unfortunately after every 2days of continuous operation igbt of one or two drives use to blow off along with 125 amps fuses connected prior to drives.
all the factors like earth-bits, input supply fluctuation, power trips, magnetic noise etc. were checked several times, shielded and found to be ok.
now my request is that if any expertise from maintenance field could give me some tips on what else could be the possible reasons behind disaster and what precautions we should absorb to avoid them.
warmest thanks,
abhijit saha
uniglobe packaging pvt. ltd.
warmest thanks,
abhijit saha
