WHAT I HAVE
I have put together a simple little mobile trolley on rails with a: Stepper Motor, wheels, serial Controller/Driver Unit, gripper, and pneumatic cylinders (total of 10 air solenoids). I am running this connected to my PC using hyper-terminal to pick and place at different slots. I was surprised how easy and inexpensive it was to get this far, and it even works.
WHAT I WOULD LIKE IS
-Simple dependable movement to location.
-Verification of positioning at the correct slot.
-Reading of the bar-code on the Picked-Up item
for verification.
-Retrieve and write location and item
information to shared SQL database files.
-Operation through PC Ethernet Network.
-Ease of set-up and operation.
QUESTIONS
-Which PLC should I be using?
-Should I be using an AC motor with Inverter or
the Stepper?
-Should I use a shaft encoder or count my slots
with a Photo sensor to verify location?
-Should I have functions and information on the
PLC or on a networked computer?
-Should I be writing a Visual Basic program or
looking at which software?
-Since all this is moving is using my wireless
network the thing to do?
I apologize for my ignorance and would appreciate any help, guidance and sources for information. Please keep it simple though. (I flunked out of Engineering school and got a Business degree.)
Thank You Very Much
[email protected]
for verification.
QUESTIONS
the Stepper?
Thank You Very Much
[email protected]
