Extruders have traditionally used either forced air, or on-off controlled water cooling on barrel zones.
In our situation water cooling is used due to the amount of heat that must be removed, and this is done with the time-honored Asco valve used in on-off (timebase 10 to 20 seconds) PID control.
For most materials and process conditions this is fine, but there are some combinations (usually, involving high throughput jobs) where we'll see cooling oscillation regardless of how the process PID parameters are set up.
In those cases, very judicious adjustment of the flow needle valve can have a remarkable effect in stability improvement. I've noted sensitivities of 1/4 to 1/8th turns out of 9 total turns - usually somewhere around 2 to 3 turns open - between satisfactory vs. oscillating control.
The other concern is that (especially with extruders running APET material, where barrel temperatures in the 500 to 600 degree range are not uncommon) valve failure tends to be one of the leading causes of process variation and/or downtime. A hardier control actuator could well be justified for this alone.
It seems to me that there could be several different approaches to extruder barrel cooling, for instance, stepper or servo driven needle valves (in conjunction with shut-off valves for when nearing 0% output).
Has anyone familiar with this or a similar application ever seen anything other than on-off Asco valves used?
