Needs help for a controls rookie.
I've been trying to set up the scales to be read on PLC and HMI. There are 2 scales currently working fine and 2 new scales that aren't being read in Data View. Both of the scales are connected through P2-SCM (AutomationDirect) near a P2-Remote Slave and the NumChars received is only 1. I tried many things to troubleshoot but not much progress so far. I tried connecting said scales at the P2-SCM near local CPU where the working scales are plugged in and they worked fine (NumChars = 16) but if I plug in another P2-SCM on the same rack as the local CPU they would receive only 1 NumChar as well. Tried messing around with the scales setting but alas.
Anyone knows what's happening here or any suggestions moving forward?
TIA.
TIA.
