K
Ken Brown
Regarding the high temp requirements w/NEMA 4 rating . . . I failed to mention that the ballscrew app discussed in my earlier post is subject to ambient temps in the range of 100 deg C with continuous water spray in the area. The motor is covered with a shroud to deflect 95% of the water, but steam and high temps are very much a part of the environment as well as the occasional blob of molten glass. . . . all wiring is water proof stainless braid flex with sealtite connectors. Most common mode of failure is when an inattentive operator allows a glass dam to
form and melts the motor leads together within the flex conduit.
Ken Brown
Applied Motion Systems, Inc.
http://www.kinemation.com
Voice 360 686 1133
Fax 360 686 1166
Ken Brown
Voice 360 686 1133
Fax 360 686 1166
