K
The card (SST PFB3 PCI) has been recognized by the System but it does not go online and geberates error.
The sys arch is as follows:
The modbus slave is connected to a MB Master (PD6 from Lumel, Poland). This also works as PFB slave to the Master PFB in PC i.e. the Card.
When I open this Profibus Configuration tool I get the card in the RHS window which I then drag and drop into DP network. Further I (ADD) drag and drop the slave (GSD File) under the DP Master, connect the Master, Make it ONLINE, Load Configuration, Open DP Monitor but no use, the card gives run ERROR.
The cable is simple, D9 pin connectors using
D+ to D+, D- to D- and Ground to Gnd, straight.
This is an SOS.
This is an SOS.
