Hi!
I am a newbee to the modbus topic and ran into an problem, where I do not have any clue how to go on.
I want to read my Heating System Control Device Danfoss ECL Comfort 210 and later transfere the results to my Smart Home System.
The documentation for the communication to the Danfoss System can be found here.
I got an Modbus USB to RS485 Converter with FT232RL Chip, connected the cables and run an test with my windows computer.
Here I was using the software "Modbus Poll" and I was able to read the holding registers.
Settings (as can be read from the Danfoss document):
Serial
38400 Baud
8 Data bits
Even Parity
1 Stop Bit
If I connect the converter to my Smart Home System (Homeassistant) and set the integration up, I am not getting any response, nevertheless the settings are the same (at least appearing to me). Homeassistant is using the pymodbus library.
Also I tried a Modbus TCP Gateway. I connected "Modbus Poll" via TCPtoRTU. Also here I am not getting any responses.
Any ideas what I am overlooking?
Thanks!
Serial
38400 Baud
8 Data bits
Even Parity
1 Stop Bit
Thanks!
