Recently DC control power for the output breaker on our combustion turbine generator was inadvertently removed. The combustion turbine generator set was sent a trip signal. However, without control power, the output breaker could not open. The set was reverse powered for several minutes. In the case of steam turbines, prolonged reverse powering (current flowing from the bus bars to the generator) can result in LP blade failure. The question that I am having trouble finding the answer to: what is the concern for combustion turbine generator sets if they are exposed to prolonged reverse power? The turbine section? The compressor section? Thanks in advance for any insight.
