We have an existing 19awg 2 pair cable that is about 900 meters long that runs between 2 pump houses. 1 pair is currently used but a relay based control system. Wanting to provide digital communications between the two locations. I realize that 485 needs a ground for reference, which I think I can get from one of the conductors in the other pair. My question is this: is there an easy way to determine if this cable will support rs-485, or am I best to go through the process of actually setting up some equipment and testing it? It does operate to the specs of the local telco, but does not interface with their network at all.
Cheers
Cheers
