Hi All,
We’ve had several RTD’s fail in the same way, whereby the sheath has split (time frame in process ranges from 1 - 5 years). The RTD’s sit in a thermowell with no chance of mechanical impact on the thermowell.
My current theory is that the thermowell has been compromised from time, vibration and being sat in an abrasive fluid. This has allowed salt and steam from the process to enter the well (this can be seen on visual inspection). Furthermore, the thermowell is likely to be made out of mild steel and the RTD is made out of 316SS. Could galvanic corrosion be possible and cause the sheath to split? I aim to get the thermowell material tested to confirm whether it is mild steel.
Has anyone experienced this failure? Could there be an alternative reason? Any help is much appreciated.
