I am setting up a PC (running Windows) that will be installed in an environment that has very little space so I don't have any space to fit a monitor in. Once I have set up the PC, the monitor will be disconnected and then the PC will be installed and run without the monitor. Has anyone ever done this before? Is there anything special I need to do, or will the PC run quite happily without the monitor? In know I could probably just try it, but how do I know if the PC is actually working without seeing what is going on? Thanks in advance for your help. Cheers, Dave Ellis
