I have done some code using the Momentum Function blocks and am looking at ways from preventing users from freely making copies for multiple PLC. User function defined function blocks can be protected, however you can still freely download the code to other PLC !
One way to protect protect the code is to read a unique code from the PLC memory like a serial number or a unique codes assiciated with the current Concept program and require the user to key in a matching authorisation code similar to practiced in some PC protection scheme. Program only run with an authorised matchin code.
I have thought of a random number generated by the PLC, however for the random code to be retentive over re-download, power cycle, the code need to be stored in a located address. Unfortunately this means that user can always type over and override the code at the located address with only one matching authorisation code and download the blocks for many PLC. (Same Code
and Same Autorisation Code)
The ideal way would be to read a unique code from the PLC memory that remains unchanged over power cycle, either a serial number which I doubt
exist, but more likely a unique code associated with the current download or program name or version.
Does aybody know how this can be done or know how to access system information for Concept? (possible with the C Toolkit for Concept ?)
Any help will be appreciated.
Derek
A-Control
Derek
A-Control
