Hello everyone,
Adding tables to P&IDs is not very common, but in my case, when needed, I add a table with the different characteristics of the elements of the P&ID. The things added to this table depends on the project, and I want to start following a standard/specification for these tables.
I believe I do no find information because it is not a general practise...but can someone comment on this, please?
Do you normally follow a spec when addying tables, and if so, which one...or do you normally add the table based on need?
Thank you very much in advance
