U
Good day,
Thanks for your reply to my query last August 26, 2009.
When the power plant nearby is on line our system voltage increases.
We are not the biggest power station operating in the area. The power
Plant in question is about 1km from our site.
Some other questions arise, please spare time to help:
We generate voltage at 11kv and steps up to 22kv. We have a step-up
Transformer. It has 3 tap change settings (22kv, 22.2kv and 22.4kv).
We are currently set at 22kv. Actually the grid system operates at 22.4kv To 22.8kv (varying) which is being controlled by a bigger power station Which has OLTC and capacitor banks.
My first question: Would it be advisable to set our transformer tap changer Setting to a higher one?
Second question:
Is there any adverse effect of running a generator at negative VAR?
This negative value actually is within the reactive capability curve.
Third question:
Can you please differentiate VAR control and Voltage control?
At what instance are we going to use Voltage control?
At what instance are we going to use VAR control?
Your reply is very much appreciated.
Tor
Second question:
Third question:
Tor
