Tatsuno Fuel Dispenser Communication to PC
Here is the OEM control scheme /protocol that I got:
GILBARCO DISPENSER CONNECTION SCHEME .................................................................................................... 25
GILBARCO DISPENSER CONNECTION SCHEME .................................................................................................... 26
GILBARCO DISPENSER CONNECTION SCHEME .................................................................................................... 27
GILBARCO DISPENSER CONNECTION SCHEME .................................................................................................... 28
WAYNE DRESSER DISPENSER CONNECTION SCHEME ......................................................................................... 29
TATSUNO DISPENSER CONNECTION SCHEME .................................................................................................... 30
TOKHEIM DISPENSER CONNECTION SCHEME ..................................................................................................... 31
TOKHEIM DISPENSER CONNECTION SCHEME ..................................................................................................... 32
NUOVO PIGNONE (MONO PRODUCT) DISPENSER CONNECTION SCHEME (RS-485) ......................................... 33
NUOVO PIGNONE (MULTI PRODUCT) DISPENSER CONNECTION SCHEME (RS-485) .......................................... 34
BATCHEN EMAIL DISPENSER CONNECTION SCHEME ......................................................................................... 35
MEPSAN UNIMEP DISPENSER CONNECTION SCHEME ........................................................................................ 36
MEKSAN / WAYNE SU86 DISPENSER CONNECTION SCHEME ............................................................................. 37
KOREA EnE (LG EnE) DISPENSER CONNECTION SCHEME .................................................................................... 38
SAFE GRAF DISPENSER CONNECTION SCHEME ................................................................................................... 39
ATG GILBARCO VEEDER ROOT TLS2, TLS-250, TLS-300, TLS-350, TLS-450 CONNECTION SCHEME .................... 40
ATG STRUNA CONNECTION SCHEME .................................................................................................................. 41
ATG START ITALIANA PROBES CONNECTION SCHEME ....................................................................................... 42
ATG PETRO VEND SITE SENTINEL CONNECTION SCHEME .................................................................................. 43
PTS CONTROLLER PCB BOARD ............................................................................................................................ 44
PTS CONTROLLER CABLINGS ...............................................................................................................................
ControlsGuy25
hello, Is it possible to have the WAYNE DRESSER DISPENSER CONNECTION SCHEME, MEKSAN / WAYNE SU86 DISPENSER CONNECTION SCHEME and MEPSAN UNIMEP DISPENSER CONNECTION SCHEME
Could you please share to my email at [email protected]
Hi Evahnce
File is too big to get attached here can you share a email so i can forward it to you...
James
Hello James
I want to communicate with RS-485. can you send me a docs for commands and instruction for ZCHENG Fuel Dispenser
Board details (from board markings):
- Board code: P/N ZC-C-01
- Firmware/revision: WXLEC-C-01 WXL20220711 V3.3
- Main chip: STC 8C2K64S2
- Copyright: GENUINE MACHINE
- Thai Version
I try to connect to the board but there is no connection at all.
Do I have to switch mode on the board too is there any doc or manual that would help
Thank you
email : [email protected]
Hi James,
I’ve been following this thread and I’m hoping you might still have the OEM connection scheme documents you’ve shared with others here. I’m working on an industrial fuel dispenser automation project in Brazil and specifically need the Wayne Dresser (Current Loop), Tatsuno, and Gilbarco 2-wire protocol specifications for the pump-side (dispenser encoder) interface.
I’d really appreciate it if you could share whatever you have on these three. Thank you very much for being so generous with this information over the years — it’s helped a lot of people here.
My email: [email protected]
