telemetry via satellite
Steve Hargraves
Greetings,
I need information on solar powered telemetry systems communicating via satellite link.
Steve Hargraves
Geo-Eng, Australia
N
Norbert Koot
I believe Vaisala out of Finland makes such systems for remote weather data
telemetry. These systems are traditionally aquired in large numbers that
are coordinated to share a private satellite transponder. For small
numbers I think it may be cheaper to use one of the new LEO satellite
dialup data links, such as Globalstar.
To: <[email protected]>
Subject: APPS: telemetry via satellite
Greetings,
satellite link.
Steve Hargraves
Geo-Eng, Australia
Robert Lockert
Steve,
We did some work in this area using the Orbcomm low earth orbit satellites
for gas well monitoring a few years ago. It works very well. I'm not sure
whether they have southern hemisphere gateways in place yet but it's worth
a look.
www.orbcomm.com
We have to contend with as little as 2-3 hrs of daylight and temperatures
as low as -40 deg at far northern installations during our winter. Solar
panel capacity and battery reserve requirements are substantially lower at
the lesser latitudes and milder temperatures you would encounter in Australia.
The system is not real time. Costs are based on the amount of data sent or
received not on the time of connection.
A typical installation is pictured at www.blocke.com.
Bob Lockert
Calgary, Alberta, Canada
>Greetings,
>satellite link.
>Regards
>Steve Hargraves
>Geo-Eng, Australia
Steve,
There is (or was) a company in the US - Kent, Washington called Meteor Communications. They have a transcever that can bounce radio signals
off of ion trails left by small meteors entering the atmosphere. Bandwidth is sufficient for monitoring remote stations acquiring data for weather or geotechnical measurements.
You might do a web search on this tip. I know the products are still be manufactured today, I do not however know if they have been snapped up
by a larger company and under a new name.
Best Regards,
Ken Brown
InTech's September 1999 issue (pages 57 through 60) has a feature called "Satellite keeps an eye on underground water." It's about how Phoenix,
Ariz.-based Salt River Project (SRP) uses a proprietary satellite-based communications technology, SPATIA, that uses Orbcomm satellites. The total telemetry-and-data package gathers and transmits water-level measurements in
above-ground basins and monitoring wells. The contact at SRP is Lee Ester ([email protected]) <mailto:[email protected])> .
C. Kenna Amos Jr., P.E.
Technical Editor, InTech magazine
ISA
67 Alexander Drive, P.O. Box 12277
Research Triangle Park, NC 27709 USA
Telephone: +1 919 990 9270
Telefax: +1 919 990 9434
ISA On-Line: www.isa.org <http://www.isa.org>
ISA is the international society for measurement and control.*
