Dear sirs,
currently i am working on a old type of welding machine. It seems that the transformer of the welding machine uses 415 Vac ( two phase only )
The primary side we have several coil to be selected by selector switch but anyway the input voltage is same. The secondary output is at 11~12 Vac with max current at 1200 A. The problem is, i was instructed to modify this ac welding machine to give dc output voltage. Is there any possibilities to convert it with most cheapest cost. I thought of using a rectifier at the
output. Will it help and is there any rectifier in market which as the capability to handle 1200 A. Please advice
Thanks in advance.
ravi chandran
Thanks in advance.
ravi chandran
