I
The setup is a compressor which is equipped with a bypass valve with a 1 second stroke time and a slide capacity valve which has a 70 second stroke time.
The slide requires to be the main and fine control, whereas the bypass is quick acting and therefore dominant.
The idea is the bypass shall act quickly to change the pressure and the slide shall catch up, also when no gas is being drawn the slide requires to close down and the bypass open to recirculate.
I am using an AB compact logics and have looked at ratio control, however this does not look like it shall react quick enough, any ideas?
