I downloaded Pactware 3.6 (arbitrarily, the Krohne) version and installed it with the intent of configuring the tag, eng. units, LRV & URV on a Siemens DSIII DP HART transmitter.
The Mactek Viator serial HART modem is on COM 1 and it apparently works OK, its ViatorCheck utility 'sees' the DSIII and reports its primary variable, as expected.
When I exit the ViatorCheck utility and launch Pactware, I can accomplish nothing in PACTware.
Attempts to 'connect' are stymied by lack of "TCI communication" (which appears to be affiliated with Profibus).
Attempts to "add device" displays HART under the 'protocol' tab, but there seems to be no method to add a generic HART device.
Project > "load from device" shows an upload status box, message: PACTware action active, one moment please; but the comm LEDs blink forever, (over 4 minutes before I gave up) without resolving anything.
Attempts through "up/download manager" to communicate go nowhere.
Under Extras > "Device Catalog Administration", "Generic HART" appears, but it isn't clear how to tie it to a device or a project, or otherwise use it.
I understand that Siemens does not have DTM's for PACTWARE, but my thought was that HART configurator software would likely do the 7-odd generic HART commands. But maybe not? Maybe it's "No DTM, no HART".
The HELP file says, "Before PACTware can be used at least one DTM must be installed". OK, so I go find & install a DTM, but will any installed DTM enable generic HART commands?
Maybe PACTware runs only devices with a DTM, but does not run generic HART?
