The maintenance routines are controlled by the system JDE but I want to make it possible to access the fields that contain the information of the work order and load them into a Palm... then the worker go to the field a make the job but once the job is done I want the Palm to symcronize the data base ( a Excell kind ) and write the fields back to the JDE data base. Does anybody nows if the JDE can import data bases from the Excell?
