Viewing Intellution Graphics in Visio package
R
Ritesh
I have a graphics file designed in Intellution IFix package and now client needs this graphic on Visio Package to make small changes. Has any one worked on converting such files , important is after converting i should be able to change size of various objects as per my needs. If some one can help pls write to me as soon as possible.
Sage, Pete (IndSys, GEFanuc, Albany)
Don't know about Intellution. But most visualization packages allow you to cut and paste your graphics between applications. Typically, the cut and paste format used is WMF (windows
metafile) which preserves the vector aspect of the graphics. If you can export as a WMF (or copy/paste) you can bring this image into Visio, Powerpoint, etc and edit it. Once your editing is complete you should be able to bring it back into the HMI. Of course the conversion to WMF will lose all the animations that you have
configured in the HMI. If you don't have any animations it doesn't matter, if you do, you may want to consider editing the object directly in the HMI.
_________________________________
Pete Sage
CIMPLICITY Development Engineer
Pete.Sag[email protected]
www.cimplicity.com
