L
Does anyone knows how to calculate the volume of fluid of a round tank with a fluid measured 2 ft below the full mark?
Also what about the expected change in volume for an increase of 10 degrees Fareinheit if the fluid is gasoline?
What would be the change in volume of both fluids if a tank contains 500 gallons of water and 9,500 gallons of gasoline with the same temperature change?
Thanks LF
Thanks LF
