R
Roy Matson
It seems as though you are leaning towards a fully automatic system so you need either a pair of level switches or level transmitter at the tank with either a wire to the pump shed or wireless system. If you are out in the country perhaps the wire could be something like a fence wire with ground return running at 24 VDC.
There are also lot's of wireless transmitters that would do the job but you would also need something smart at the pump end.
Another crude idea would be to have a level gauge on the tank you could see from the pump shed. You would look at the gauge then set the pump run-time on a simple timer.
