What is the most reliable way for control of Waste Heat Recovery units on Gas Turbine Outlet. Single blade damper with a spring return actuator is what is generally acceptable. But when you want temperature control with these actuators & single blade assembly the lag in the system will be high, so to go for multiple blades/vanes will be more effective? What else can be an option with due consideration of safe shutdown.
