I would like to hear some examples?
What is communication interlock for an automated application?An interlock is a condition or series of conditions that must be met to allow an operation or process to continue. Examples are numerous, but some general examples include:
shield interlock- the machine cannot run unless all the safety shields are closed
flow interlock - the operation cannot continue unless the coolant flow is adequate
pressure interlock - the operation cannot start unless adequate air or hydraulic pressure exists.
level interlocks - the pump cannot run if the tank level is too high or too low.
presence interlock - an operation cannot start until a part is detected in the work station.
The term is often used loosely and can refer to a phsical device (such as a switch, sensor, or meter), or a control circuit, or a sofware construct, or a specific function. Another common term is "permissive," although permissvie is usually, but not always, more limited to software references.
Difference vetween an interlock and a shutdown | General Automation Chat | 1 | |
| I | Interlock, TRUE or FALSE | Programmable Logic Controller - PLC | 2 | |
| S | Interlock Diagram Software | General Software Chat | 0 | |
| U | Demineralized water plant concentration analyzer interlock | Process Control | 0 | |
| A | process interlock and safety interlock?? the difference? | Safety | 13 |
