It is for the base plate on a Trident. I tried that pin out, a standard null modem cable.
Also tried a few variations. No joy. The latest manual (I have in my paws) actually call out the part number for the cable,
And have this verbiage:
This figure depicts the RS-232 serial cable, which is a standard null-modem cable used to link the serial connector on the MP Baseplate to a PC acting as the Modbus master.
Pg 41- The MP baseplate serial Protocols are-Slave, RTU mode, optional parity, 1 stop bit. The MP baseplate Ethernet RJ-45 Protocols are- TriStation 1131
It looks like you have to use a RJ-45 Ethernet cross cable as your Trident to Tristation PC connection. The MP baseplate has 3 Tristation ethernet ports.
In my experience, Ethernet is much better than a serial connection for program monitoring and downloads.
Other documents recommend using the serial port (on the comm module baseplate) for the first connection to the system. Several reasons.
Sure I agree, IF, you know the IP address. If the system has been configured and the IP address is unknown, the only method to connect is the serial port.
I was able to use the same cable pinout as an Allen Bradley 1747-CP3/1756-CP3 to communicate with serial port three on a Trident CM3021 using the Tristation software.
