We have a GE Frame 5 M combustion turbine that is having lube oil problems. When on the A/C lube oil pump the pump discharge pressure is 22psi. We are loosing 6psi across the heat exchanger. We loose another 1psi across the filters. That leaves our header pressure at 13.5 psi. We have a single cooler setup. Currently we are operating 1.5 psi above alarm on startup. When the gear pump kicks in the lube oil system is fine. Is it ok to continue to start the unit at 13.5 psi?
