Hi all, new here and new to the automation field. I am using a Trio Flex 6 Nano plc and a Proface LT4301m HMI. I have a drive, servo, ethernet hub and sensor all hooked up (just created this setup to practice on). I have the sensor connected to the HMI and thats working correctly, as is the servo. What I'm trying to do is set up communications with the PLC and HMI using ethernet. I want to spin the motor when the sensor is tripped and play around with the programming etc... Using GP Pro EX 4.08 for the HMI software. Can anyone help me set up Motion perfect and GP Pro to communicate with eachother please?
