Tram , I have Installed these Auma valves but there's a FAULT on the dashboard reading TSO and machine cant start In Local mode
Can you share OEM reference...Tram , I have Installed these Auma valves but there's a FAULT on the dashboard reading TSO and machine cant start In Local mode
You know the problem started when the valve closed and hits the end. At the moment it cant move or startCan you share OEM reference...
Also by the way what is Tram..
Well we still need OEM ref for better investigation and troubleshooting...You know the problem started when the valve closed and hits the end. At the moment it cant move or start
