Hi Team,
To troubleshoot the communication loss issue with the Socomec D50 multi-master gateway, let's break down the setup and potential causes:
Setup:
1. PDUs connected to Tap-off-box for monitoring (voltage, CT, kWh, etc.)
2. Tap-off-box connected to PDU gateway
3. PDU gateway connected to PDU HMI
4. Both PDU gateway and HMI connected to rack Ethernet switch
5. Switch connected to BMS monitoring system
Potential Causes:
1. Network Congestion: Insufficient bandwidth or excessive network traffic might cause communication loss.
2. IP Address Conflicts: Duplicate IP addresses or incorrect subnet masks can lead to communication issues.
3. Incorrect Gateway Configuration: Improper setup of the Socomec D50 gateway might cause communication loss.
4. Firmware Issues: Outdated or corrupted firmware on the gateway or PDUs might lead to communication problems.
5. Hardware Faults: Faulty Ethernet cables, switches, or other hardware components can cause communication loss.
6. Power Quality Issues: Power fluctuations, surges, or electrical noise might affect communication.
7. Tap-off-box or PDU Issues: Problems with the Tap-off-box or PDUs, such as incorrect configuration or faulty sensors, can lead to communication loss.
Setup:
Potential Causes:
