G
I am upgrading instruments on a 30 years old 5000HP Motor driven gas compressor (I kid you not). As part of the upgrade, I have suggested redundancy of thrust probes A & B on the Compressor Outboard thrust pad and even added further additional monitoring points on the radial axis. (Including a new installation of dual redundant thrust probes on the helical gearbox)
However, the Operations dept require the single radials to be redundant with additional probes in an X-Y axis.
I was hoping for a degree of flexibility here with the age of the machine in question and also the fact that the radials are easy to get at (Maintenance point of view) where a high vibration would trip the machine and a failed probe (Eg. Low/ no vibration) would Alarm at the Vibration Controller & Workstation alerting maintenance to change it out.
Obviously I do not wish to impede the safety & protection of the machinery with my suggestions but after 30 years of the current installation and limited budget I am trying to be practical.
Therefore, is API recommendations mandatory? Are there any Specs that are mandatory or is it all on a Clients whim? He'll be wanting to know the speed next!
Hope you can assist
Thanks in advance
Gray
Hope you can assist
Thanks in advance
Gray
