N
I have gas turbine power plant frame 9. sometimes i found trouble on bleed valve actuation system. almost in each inspection i found dirt and corrosion on actuator bleed valve and also on solenoid bleed valve 20CB-1. it's very dangerous when the unit on running condition, because bleed valve is used to protect compressor from surging pressure on 11th stage of compressor's blade. actually, the operator can shut off the bleed valve manually using manual butterfly valve. but there are two bleed valve located on extremely dangerous area which is located in narrow space and high temperature area. so it would be so difficult for operator to the protection manuver.
What could be the consideration if we change the pipeline position of these two bleed valve below the gratings??
I,m hoping some suggestion from who has experience and knowledge about this. Thank a lot
