Hello everyone!
I have a problem with generated reports with offset time. I'm monitoring the SUM value (trend) of an flow instrument, so that is a cumulative value (not taken directly from an instrument, but in trend history data). Reports are generating normally at wanted time, but the offset SUM value of measured flow is not nearly ok. I set up a resistor to AI card terminal (where the instrument is connected, so the value of measuring is constant). All i'm getting is a non linear deviation of measured data for that field instrument (for example every 2 hours)...
I'm not getting anywhere with this, so please help anyone...
