Hey Guys,
new member here. I am trying to figure out a solution for a chemical mixing system we have at work. Currently we are mixing a chemical and water, both of which are individually pumped into a mix tank through flow metered circuits. Currently the system works by controlling the valve open time on both circuits in order to provide a proportional mix as determined by the ratio determined in the HMI. The issue is that the value that is used to validate the chemical is within spec is the TDS. We have found that the TDS of the bulk chemical is fluctuating a significant amount from the manufacturer, causing a need to constantly change the proportions in the HMI when the system is supposed to be fully automated.
My theory is that instead of using proportional mixing, to instead go to a control based off the actual live value of the TDS with a EC probe in the mix tank. The water level will be controlled to a set point with an existing ultrasonic level sensor. Then chemical pump (flojet pneumatic diaphragm pump) will be controlled with a simple on/off control based on the TDS value being within tolerance or not similar to a PID controller. This way the system can compensate for the discrepancy in TDS from the manufacturer.
Does this make sense? Am I missing something here?
I am new to all this and would love to see other solutions.
