What would be the easiest way to connect a A250 to SCADA system Wizcon or to an OPC Server? It should be a fast connection (not RS232). Which hardware on PLC side and on PC side is needed?
What would be the easiest way to connect a A250 to an OPC Server? It should be a fast connection (not RS232). Which hardware on PLC side and on PC side is needed?
We are interested in above mentioned solution.
