if flash draining?When crank cooling, do you need to maintain drum levels HP/IP/LP drums of hot dumping boiler?
Helloif flash draining?
| A | GE frame 9e speed fluctuation during crank mode (gas turbine purge) | Power Generation | 6 | |
| M | Crank Cooling 7FA | Power Generation | 3 | |
| I | Force Cooling by Running Crank 10 hrs Continuously | Power Generation | 1 | |
| A | Crank Speed for Rapid Cooling | Power Generation | 1 | |
| T | 7FA Gas Turbine Crank Cooling | Power Generation | 13 |
